TwinTurbo.NET: Nissan 300ZX forum - I'd wait on the Water Pump
Cjw3
on February 13, 2023 at 5:28 PM
Re: overheating a little bit, removing thermostat fixed it
posted by tian2bing
on February 12, 2023 at 02:11 PM
Do some Testing as Suggested.. Either the Combustion Gas in the Radiator Test, or the Bubbles when the Cylinder is Pressurized.
tian2bing
08:24:17 02/10/23
coolant temp needle is half way when lukewarm (n/m)
tian2bing
09:14:22 02/10/23
Removed the thermostat, or replaced it?
LitlElvis
11:05:18 02/10/23
I should have been more clear:
tian2bing
12:06:23 02/10/23
Lets Discuss..
Cjw3
12:14:45 02/10/23
Re: Lets Discuss..
tian2bing
12:41:41 02/10/23
Heater Core has no effect on Engine Overheat
Cjw3
13:23:14 02/10/23
Re: Heater Core has no effect on Engine Overheat
tian2bing
22:18:42 02/10/23
not good!
Cjw3
08:32:15 02/11/23
What bubbles are you referring to? I didn't see mention
ZXoltan
10:38:32 02/11/23
Do a combustion gas detection for CO in coolant system, >>
ZUL8TR
14:29:48 02/11/23
Common bad head gasket symptoms. (n/m)
mrchips
05:09:49 02/12/23
tian2bing
14:11:18 02/12/23
I'd wait on the Water Pump -
Cjw3
17:28:59 02/13/23
thxs all the help. Now puddle under car.
tian2bing
02:47:31 02/20/23
Re: thxs all the help. Now puddle under car.
tian2bing
04:33:42 02/20/23
There is a common hose leak over the trans bell from the
10:47:00 02/22/23
Yup! Big 2nd (n/m)
FrozTTy
17:03:25 02/23/23
